Hi guys
Has anybody managed get harmony or SofaBaton to work with rs150b ,
Would like to be able to turn on the rs150b power amps tv and virgin with 1 remote
please use the Bluetooth remote control provided by Hi-Fi Rose. Even if you pair the remote with a different brand, pressing the play button may activate other functions and there are several problems.
Once again, we recommend you to use Hi-Fi Rose BT remote.
Does Rose Audio sell extra remotes? What happens when our remotes die, would we even be able to buy a replacement?
This is important as Logitech Harmony either can’t or doesn’t want to add HiFi Rose products onto their database.
Please contact the distributor in the country where you purchased the Rose device.
