My unit won’t turn on…
When pressing the on button I can hear the relay but the display not turn on…
Try to disconnect power and push the reset button…
Nothing helped…
Any suggestions???
Probably send it back to the shop or distributor for checking.
If the power cable is properly connected and the power does not turn on even though the relay is heard when the power button is pressed, it seems that you need to contact the distributor in the country where you purchased the RS150 and have it repaired.
