Hello Community ,
My RS151 doesn‘t Show up on my devices as an AirPlay receiver. Do I need to configure Airplay on my RS151. Network works, Ethernet . Any hints for me?
Latest SW installed
On the home screen, in the top right corner, there should be icons for Spotify, Qobuz Connect, DLNA, and, yes, Airplay (some may be hiding behind the “…” button). Make sure it is turned on.
