I’m think of buying an Rs151. I always listen in the dark and the streamer will be 5 meters from my chair, so I will not normally be using the screen. Can it be turned off so it is totally dark? Even better, can it be completely disconnected to eliminate any added noise or interference with the sound quality?
/20 characters
? Sorry, but I didn’t get your response, just a partial quote from my post.
I own a RS150b and the screen can be turn On/Off from the Rose Connect app. The RS151 probably do the same.
…and the believers in unicorn poop are out in force again…
When the RS151 screen is completely turned off, audio playback is not possible.
We recommend using the RS151 with the brightness set to minimum.
