Trying to update RoseTube on my RS151 (as suggested by RoseOne), the “downloading installation file …” never ends (at least within 15-20 minutes). The way to resume is to press the back button (arrow pointing left) on the remote control or to turn the RS151 off and then turn it back on.
So I’ve thought to unistall RoseTube and tried to install it again with the same result: stuck at “downloading installation file …”.
At the moment I haven’t Rosetube available.
What should I do?
