Rs151 vs rs150b - cold sound
Dear friends, I hope you are all doing very well.
I would like to know if the rumors circulating on review sites and from supposed users who have tested the HiFi Rose RS151 are actually true.
In theory, at least on paper, this model represents an improvement over its predecessors, and its DAC is next-generation. However, I’ve read some reviews stating that while the sound is precise and detailed, it lacks the warmth and character found in models like the RS250A or RS150B.
Has anyone here had the chance to try the RS151?
I appreciate your comments in advance. Many thanks!
I had the opportunity to test the Rose RS 151 and it is definitely a good sound, i.e. detailed, drawing a lot out of the song, the vocals are not exaggerated in detail and obtrusiveness, although it is not a super warm sound, so if someone has a system that already plays quite high, the Rose will probably not approach, it is better to buy e.g. some Lumin, however, if someone has a neutral system, then you can definitely go into the Rose RS 151. And you can still warm it up a bit with cables.
I changed from 150b to 151. I have a very nice tube preamp running through a very clean solid state amp. I didn’t lose any warmth at all on the switch. The sound is non fatiguing and accurate. The display screen is much improved. The software update to 5.9 was a complete disaster but has been somewhat resolved.
I’ve had the new RS151 since March and it’s a great streamer. While I’ve never tried the RS150, you can’t go wrong with the beautifully made component!
It has both warmth and detail and is easy to operate. As for the excellent DAC, you can adjust the filters to your liking, which is a huge plus.
I’m using the RS151 with a McIntosh MA252, Devore 0/96 speakers, REL S-812 and paired it with my Clearaudio Performance TT with a Hanna MH cartridge. While I also have an excellent CD player, I now rarely use it after getting this streamer.
I’ve also added a Sony Bravia monitor to this system. So in addition to watching 4K videos with no ads through their RoseTube, you can also display the album art while listening to the music, which I personally enjoy even more than looking at the art on my many LPs. (While I miss the detailed program notes, I can always find them on my LPs, if desired.)
Hey friends,
I’ve had my RS151 since August 2nd, and honestly, the sound is just awesome.
From my own experience, I can say the whole “cold sound” thing is kind of a myth. Paired with my PrimaLuna EVO 300 Hybrid (with Brimar CV4003 tubes in the pre stage) and my Wharfedale Elysian 4 speakers, the RS151 delivers a sound that’s warm, detailed, and super well-defined. You can really feel the space and depth—of course, that also depends a lot on the quality of the files you’re playing.
In my setup, I’ve got the FIR INTERPOLATION PHASE FILTER set to:
MINIMUM PHASE SLOW ROLL-OFF Filter (same setting I used with my RS250A).
Like with any new gear, it needs some hours of use to really open up and give its best, but so far, I’m really happy with it.
There are still a couple of things in the user interface that bug me a bit, but I guess those will get sorted out over time.
Cheers from Buenos Aires!
Hi I’ve only had a few days with my rs151 and all say I don’t find it cold its precise and very wide soundstage I have paired it with warm components and to me sounds miles away from cold I believe this streamer needs more consideration when choosing speakers and amplification
Hello, I’m going to audition the Rose RS 151 again. Could you tell me where to go in the menu to play around with the DAC’s filter settings? Which of these filters do you think is the best in your systems? Best regards.
Rus.
I agree with you 100%, it’s always the combination of several elements. RS151, it’s truly fantastic.
Cougar2025.
You have to go to the settings menu as shown in the photo, press the wheel, and then, as seen in the second photo, modify the filter.
NEW-02-2000mV Filters
Yes its a awesome bit of kit great sound more depth than eversolo a10 just wished software was more intuitive my only problem is getting sound out when trying rosetube on my tv
No sound coming out of amp but works fine on the streamer
Hi how do you display album art on your tv
Connect the device via HDMI to the TV, select the appropriate input that you assigned to the Rose connection and you will have the cover of the given album displayed on the TV.
You simply plug your monitor in with the HDMI connection and turn it on with its remote when using the RS151 and amp. When you then play an album, the cover art will appear on the monitor in full 4k resolution while listening to the music. I personally no longer use the RS151 without using the monitor. It’s that good!
I’d recommend using a smaller HD monitor so you can concentrate on the music.
