Rs201 VU Meter not working at all
I have turned on the VU Meter function and use rs201 play Tiald as source, but no meter can be deplay.
If you’re using external DAC, VU mode may not work. This issue should be fixed in next update.
If you’re not using external DAC, check here.
RS201 > Play TIDAL > Go to playback display > VU mode button on TOP RIGHT
ok, got it, thanksss
