RS201a Optical Input no longer auto sensing
Since last update it seems I need to plug and unplug my optical cable for input to kick in.
Any ideas? Thank you!
  1. How did you identify the OPT IN connection being disconnected?
    ‘OPT IN’ in IN/OUT Setting was disabled?
  2. What should you do to disconnect the OPT IN connection?
  3. Did you completely turn the power off and then on again? Or did you use sleep mode?
  4. Is USB/SSD power activation in standby mode OFF?
    (RS201 → Setting → SystemSetting → USB/SSD power activation in standby mode)
Please let me know in detail so that I can help you.
