RS201E standby problem
Such a flickering screen problem. Can it go bad if it continues like this?
@maniekf
I apologize for the late reply.
As a result of checking the symptoms, it seems to be a defective LCD problem.
you may need to contact a distributor in the country where you purchased the RS150 for LCD repair.
Thank you for your answer. The problem does not appear right away. The average time is 3 days and then the problem arises. There is no hope of solving the problem via firmware?
@maniekf
Does the symptom appear only on the standby mode screen?
Yes!
Only.
Mariusz Ferster
@maniekf
For this symptom, we will test whether the same symptom occurs in RS201.
If this phenomenon occurs only in standby mode, it may be resolved through a firmware update.
Ok. I am waiting for information and waiting for a solution to the problem
