RS201E VU meters with Roon working
Hi, from reading these forums, I thought the VU meters didn’t work with Roon? I can confirm that they are working on my setup, using the 201 as streamer only and the digital output into a tdai1120.
It won’t let me change the VU type though, but they are working ok. Can the type be changed, the app says the VU isn’t available?
Thanks.
I found out that if I stop Roon, I can then change the VU meter, then restart Roon and the VU meter works again.
