My Apple products (iPhone, iPad, and MacBook) cannot find my rose RS250 anymore for airplay streaming since the last update!
Is there any thing to do in the setting?
Would you turn off WIFI(or Ethernet) and turn ON again?
RS250 > Settings > WI-FI or Ethernet -
Do you see IP address here? What’s written?
RS250 > Settings > SystemInfo > IP address
Thank you. After having turned it off (Ethernet ) and turned it on again my problem was solved.
Really appreciate your help.
Regards
