Im trying to read internal Rose hard disk by computer, but Its impossible to see files.
I desmount hd from Rose and I connect hd directly to pc.
I see hd letter but no possible to managed files.
Maybe windows dont read rose hd? Maybe the format system is different?
I sell my RS250 so I cant read music anymore. I lost all music?
thanks
Please check a few things.
Is your HD formatted as NTFS/exFAT/FAT32? If formatted in any other format, Rose device may not recognize the HD.
How many TB of audio or video is currently stored on your HD?
Hi, maybe you don’t understand my question. I had HD in a RS250. Now i sell it so I removed. My problem is my computer read HD but i don’t see any music to managed. Whitout Rose I cant see my music. I have Windows 10
That’s normal.
If you previously stored HD on the RS250 and now removed it, it is natural that the sound source recognized by the RS250 cannot be confirmed on the PC.
Ok, now i buy RS150B and installed. I have music same 250.
How I can resolved that problem? I have to formati by pc before install?
@Taccola
Please check the video below and reconnect your Rose device and PC via network.
There is a possibility that the existing network was deleted during the update.
For Windows: www.youtube.com/watch?v=wVx63z86jE4
For Mac: www.youtube.com/watch?v=L98EFsW1Eoo
Thanks for video but my problem is different😁
Why, after HD removed from Rose, i dont see any files in my computer?
Maybe Rose used a format system different from Windows? Its Linux formatted?
If you connect the HD to the Rose device and scan it, the Rose device scans so that you can quickly load the music stored in the HD.
From the moment you disconnect the HD from the Rose device, the music stored on the HD is deleted from the Rose device.
So, when you connect your PC to the Rose device wirelessly, you will not be able to view the previously scanned HD music files on the Rose device on your PC.
I connect ONLY hd to pc, without Rose! No problem about network, about Rose, about comfiguration. I dont see any file when i connect rose Hard Disk to pc by usata adapter
You connected the HD directly to the PC, but you can’t see the sound source in the HD on the PC?
It doesn’t seem to have anything to do with the Rose device.
How can I help you?
You’re screwed. You need the rose to read the drive.
