RS250 Internal DAC - Analogue Output to Integrated Amp?
May I confirm that the RS250 has a internal DAC which means I can connect the RS250 to a Integrated Amplifier without the need to use an external DAC? The information on the web seems to suggest that the RS250 acts as a Pre-Amp and has to be connected to a Power Amplifier directly.
Hello, you may connect RS250 to Integrated Amp. No problem at all, please use RCA cable.
Also, don’t forget to change output in ‘IN/OUT Setting’ of RS250.
Thank you ROSELOA. Appreciate your quick response.
