Hi - i have a noise/burnishing problem on my new unit. It does not make the noise on the usb audio out to my hi end dac-amp, but it does on the analog rca output (the golds output on the right). The amplify when turning the volume knob. Any recommendations to attenuate the noise? Thank you.
- Does the same happen after removing all cables except power and RCA cables?
- Did you connect RS250 and Amp ground?
- Has it happened since purchase? How long after use did it occur?
Hi - yes i grounded it, no change. It did it since purchased. I also tried to put each components far away and analog only. I disabled in the menu bluetooth and wifi to use wired.
Thanks.
