Hello, when I connect my Samsung Smart TV through SPIF (cable optical in on the RS250), a time lag problem occurs that is quite noticeable between the image and the sound (jitter). Please help me fix it, I have tried in the configuration to reduce the delay to 0ms in PCM and the audio and video are still out of sync. Your help please.
The sync should be good and in most cases it is, but it seems that in some cases it may not be synchronized. We are continuously investigating the cause and will issue a patch once it is resolved.
If you follow the few methods below, you will see some improvement.
Please factory reset your RS250.
RS250–>Settings–>System settings–>Factory reset -
Please turn off the VLC Player function before use.
RS250–>Video–>Gear icon at the bottom left–>Use VLC player off
It’s been almost two years since the announcement that the problem would be investigated and resolved, and I still have audio delays when connecting my Samsung TV to the Rose RS250 via optical cable.
@ROSEHAN I’m asking for more information and urgent help.
Please check one thing for me.
Does the audio delay still occur even after setting the PCM Delay Time on your RS250 to 3000ms?
You can find it here:
RS250 → Settings → PCM Delay Time → 3000 ms
changing the PCM delay in either direction does not make any difference
Your issue has been forwarded to our software and hardware teams.
As soon as we receive a response, we will let you know immediately.
We apologize for the late response due to the delay in investigating the cause.
Thank you for your help in improving the quality of Rose products.
To help us clearly identify the delay phenomenon you inquired about (e.g., whether it’s a TV compatibility issue), please record a video of yourself with audio using your smartphone and send it to the email address below.
shim1691@citech.kr
We have investigated the issue where an approximately 200 ms audio–video delay occurs when using external inputs (Coaxial / Optical / ARC In) on the RS150 and RS250.
If adjusting the PCM delay time does not resolve the issue, it is currently difficult to improve this behavior due to the product’s structural limitations.
