Does anyone know if RS250 (first model) supports WiFi 6?
RS250 supports WiFi (802.11 b/g/n/a/ac) 2.4Ghz/ 5Ghz dual band.
A WiFi 6 router supports 802.11 AX.
RS250 does not support 802.11AX, but when connected to a WiFi 6 router, it is automatically backward compatible with the WiFi 6 router. So you can connect to the WiFi 6 router.
