New Rose owner here. I’m not having any luck playing files from my Synology NAS. The RS250 can locate the NAS and I can enter user ID/password then select the “Music” folder. I can see all of the artist folders and albums etc. The Rose won’t play or scan the the files though. It says “No such file or directory”. SMB 1 is enabled. Tried on the Rose Connect app too. I have no problems connecting to the NAS via Bluesound Node or SACD player.
Tidal and other apps are working fine
