RS250 won't start
RS250 does not start. Was working perfectly for past month. Today, it would not turn on. I unplugged HD and still nothing. I unplugged from wall with same result. Holding down power key for 5+ seconds produced a brief display of HiFiRose logo but nothing else. Help!
Hello @mww
  1. If you press the power button, does the LED light blink from the power button?
  2. If you press the power button, does the back light shows from the screen?
Please let me know which of the above applies, if not please contact the dealer where you purchased.
Please contact to your distributor and get help about this issue.
Check what dushbag96 asked you and let your distributor know about it.
