My library and the music I listen to most is on an external SSD drive attached to my RS250A. Is there an easy way to create a playlist from those files and folders on the drive?
In the past I had used a PC to play music and had easy access to the music on the drive and was able to just drag and drop the files into a playlist including and music that might be in a subfolder too.
I have 1000s of folders and files and would like an easy way to add specific folders to a playlist.
Is there a way to do this other than taking each file and adding them to a separate folder and just shuffle play that folder?
Looking for some advice.
Thanks.
