Dear Friends, it is a pleasure to greet you.
On this occasion, I want to comment that my Hifi Rose - RS250A, which I bought a couple of weeks ago, raises a lot of temperature when used.
I don’t use the equipment to connect to the Internet; My only purpose is for it to function as a DAC with display to play from an external USB hard drive.
I await your comments, to know if this is normal, or if I should adjust some settings.
Note: I use the equipment on weekends, and when it is not used, I disconnect it from the power and it remains completely off.
Greetings from Buenos Aires, Argentina.
José.
