Rs250a + Rd160 connection
My RD160 is on it’s way and before I upgrade to Rs130 I need to connect it to my Rs250a
Can you please recomend what port/cable to use between the Rs250a and the Rd160.
I was thinking of usb A (usb audio out) at the rs250a to usb B (pc audio in) at the rd160.
I am using only Tidal.
Is this the best connection or should I go with Optic?
I would prefer the USB connection over SPDIF (clock, bandwidth,…).
By the way: I would buy the new RS151 instead of the RS130/RD160 combi, if you don’t need the DAC for other sources.
Thanks for the info.
