RS250A screen cleaning
Dear Friends!
On this occasion, I want to ask you how and with what product the RS250A touch screen should be cleaned, given that all the fingers are marked.
Thanks for the help and greetings, from Buenos Aires, Argentina.
José
With the 250 switched off, clean the glass panel with a microfibre cloth.
I do not use any cleaning solution, just use the cloth.
I do it weekly.
Thanks for the advice, I’ll do it that way.
You mean a liquid lens cleaner?
I use 'iKlear Cleaner/Polish for Apple’ 6oz/180ml spray kit available from Amazon. Original kit lasted many years for various monitor screens, iPads, iPhones, tablets, touch screens, glasses, etc. Comes with various micro-fibre cloths.
Hello everyone!
I’m a little scared of using liquids in equipment that costs a lot of money…It would be interesting to receive advice from the manufacturer itself, to see what they tell us.
Greetings from Buenos Aires, Argentina.
José.
I won’t remove the protection sheet.
It is a good screen that does not dirty quickly, I clean it with a screen cleaner tv… bought from Darty (France), it’s perfect, safe and economical.temium_kit_tv_2x60ml_s1901304636937A_115355768
