Hi, I’ve not had a chance to listen to my RS250 for a month or two and on switch on tonight, it plays maybe a song and a half from the internal hard drive then stops. If I hit the play button again it starts the track again from the start. I’ve tried a factory cc reset and it still does it.
Weird. I came online to post same problem with rs130. This is for dsd256 played via usb
Please check a few things.
- Do you experience this symptom when you play DSD sound sources? Or do you experience the same symptom when you play other sound sources that are not DSD sound sources?
- Does this problem always occur when one and a half songs are played?
- Do you experience the same symptom even after deleting all the DBs in your RS250 and rescanning?
Go to RS250–>Settings–>System settings–>Media Library–>Delete the DB of the external hard drive and rescan the DB.
Thanks for your reply. I was just about to come back and report that I’ve. Fixed the problem: I deleted and rescanned the database. And all is good now
