RS280 Volume Functionality with Bluesound Node
Hi Guys,
Looking to grab the RS280 and a Bluesound Node (Until I can afford RS130!), and just wanted to check and make sure that, if I’m controlling the bluesound audio through my TV remote using ARC, that it would adjust the amp correctly?
Thanks in advance!
-Brandon
@B72783
The volume of RA280 cannot be adjusted using the TV remote control.
TV ARC out–>bluesound audio ARC in -->RA280–>Speaker
It seems to be possible to use it without any problems when using the above connection.
