Hi Rose , i have 1unit RS350 unit internet radio many channel can’t play (Say cannot be opened temporarily) any
firmware to update ??
There have been no recent firmware updates for the RS350.
If there are any specific radio stations you would like to listen to, please let me know.
I will try to find the streaming URL for those radio stations and show you how to add them manually to your RS350.
Hi sorry to late reply , like all Malaysia radio stations all can’t steaming
I have forwarded this issue to our software development team, and they will review the problem and work on a solution. Since this requires investigation, it may take some time before a fix is available.
In the meantime, if there is a specific Malaysian radio station that you would like to listen to, please let me know the station name. I can guide you on how to add that radio station manually so you can use it while we work on resolving the issue.
Thanks in the meantime can you help on My.com-Lit , Myfm-My Fm , Mix FM 94.5FM & Melody FM 103FM this 4 radio station
I requested our software development team to add support for Malaysian radio stations on the RS350 and RS301. However, I was informed that Malaysian radio stations are no longer supported by the server used for the RS350 and RS301, so unfortunately it is not possible to add them.
