I have a HiFi Rose RS520 (latest firmware) and I’m want to use it as a USB DAC with a MacBook Pro M1 (running the latest macOS). When I select “USB In” and play audio via USB:
1. The audio signal plays very loudly for the first second (a popping sound).
2. After about one second, the sound goes completely silent.
3. The RS520 no longer responds to volume adjustments or audio input until I restart it.
I have tried the following:
• Tested 44.1 kHz / 16-bit in Audio MIDI Setup.
• Closed heavy applications, restarted the unit, and tried different USB cables.
The issue seems related to USB DAC handshaking on M1 macOS, which aligns with similar reports from other users on Apple forums and Reddit.
Could you please confirm if there are known instabilities when using RS520 as a USB DAC with M1 Macs? Is there a planned fix or any recommended work around?
Thank you very much for your help!
Best regards,
Staffan
