It seems that the functionality fails when playing spotify over bluetooth
Rose device is made based on Android, so there are some functions that cannot be selected or do not work when connected with a BT remote control.
When using Airplay, previous/next song and Pause/Play do not work.
And it is normal that it should work when playing Spotify over Bluetooth.
Can you tell me how you connected and using it?
