RS520 DSD to Reel to Reel
I have an RS520 that will play DSD files stored on my Roon. I’d like to record DSD to my Pioneer 909 reel to reel tape.
Can I use the pre-amp outs into the reel to reel inputs. Then the reel to reel outputs back to the analogue inputs on the RS520 and play at the same time so I can hear what is being recorded?
Make sense?
No. That won’t work. You can only listen to the same as the output. Because the analog input goes through an ADC to the DAC to the output. The DAC can only work on one or the other.
