RS520 No Wi-Fi connection @ startup
On my new RS520 I found out, that in the morning- starting the divice- no Internetradio is available.
“No connection to service” The Wi-Fi Icon in the right upper corner of the display is dark.
Every morning I manually have to tip on the Wi-Fi Icon, going into the list of available Wi-Fi´s.
Not till then the Rose connects to the Wi-Fi.
After that I have to start the stream also manually.
I expected a “one-click” handling. Switch it on, and the last source will be played without any
additional doing.
What do I have to do, that the Wi-Fi connect automatically with startup?
Thanks for tips.
Bernd
I’m sorry we do not support ‘one-click’ handling.
Still, WI-FI should be connected automatically when you turn on the RS520…
  1. Do you totally turn off the RS520? If so, would you try standby mode? (press the power button shortly)
  2. Would you check if this setting is ‘OFF’? Try ‘Auto’
    RS520 > Settings > System Settings > Activate USB/SSD power on standby mode
Best Regards,
Thanks for the hint. Activating the USB/SSD power to standby mode helped to keep the WiFi
active.
