My 10 days old RS520 is making a popping (crackling) noise on the right channel. It starts after 2-3 mins after is being turned ON, regardless on the input source (Radio, Spotify…etc).
Below is what I tried so far:
- Turned off the RS520.
- Ensured the speaker wires are properly connected to both the speakers and stereo receiver.
- Tried a different input/source.
- Turned off any nearby electronic devices that may be interfering with the speaker sound.
- I replaced the power cable, the speaker wires and I connected a different set of speakers. Issue is not resolved.
- Moved the speaker wires away from any electrical cords.
- I swapped the speakers around then I tried with a different set of speakers.
The issue is still unresolved - I then: reset the receiver to the factory default settings, plugged in the RS520 in the garden’s Summer House which is on a different power circuit, same issue - the right channel is making popping sounds.
I will call tomorrow the shop I purchased the unit from, but I wanted to find out if anyone can recommend anything else? Thank you.
