@Smegel
Thank you for your detailed feedback and for taking the time to test various scenarios.
We understand your observations regarding the USB-B connection, docking station usage, and the stability after reboot. Your suspicion about the unit becoming unstable after long standby periods is also noted, and we will share this with our software team for further investigation.
Regarding the volume synchronization issue in Rose One, we also understand your point about the current behavior. We will forward your feedback, including your suggestion about event handling (push vs. polling), to our development team for review.
For now, we recommend continuing to use a direct connection (without a docking station) for testing, as you mentioned, to rule out any external factors.
We truly appreciate your technical insight and detailed explanation. It is very helpful for improving the product.
