RS520 sleep mode keeps triggering sometimes in seconds after OS upgrade
My first post here. Hope this is the correct place to ask. I did a search but nothing I found quite addressed what I am experiencing.
I updated my unit a few days ago after which tried using a sleep timeout. Since then it repeatedly shuts itself down, usually after less than a minute but often within 10 seconds. The unit is effectively unusable.
I have tried;
  • shutting down the unit, unplugging it and let it stand for almost 24 hours
  • tried resetting the sleep timeout to a long time
  • shut down every Rose app on all the Android devices in the house
  • combinations and repeated attempts of all of the above.
Sometimes, the shutdown is so quick I can’t even get to use the menu from the front panel, ie less than 10 seconds.
Anyone give me a clue as to what is going on and how I can actually regain a usable device?
As you mentioned, this seems to be an issue that hasn’t occurred before. If you have enough time before it turns off to tap the buttons, could you please try a factory reset via:
RS520 → Settings → System Settings → Factory reset
Full factory reset didn’t fix it. Still turning off at random timings, none of them very long. It has turned off three times since the reset - with a max of about 3 minutes duration I guess.
EDIT
Also, just discovered a new fault - the RH audio output is also not working since the upgrade and the reset. I have also had three more self shutdowns while doing these tests and trying to play an input.
I tested this by;
1 - swapping the output cables over. The RH speaker then responded to a test signal
2 - swapped the output cables back and retested. The LH speaker now responds
3 - swapped the input cables over - RH speaker responds
4 - swapped back - LH speaker responds again.
Based on the symptoms you described, this issue appears to require a hardware inspection. We recommend reaching out to the dealer where you purchased the unit to arrange for service and repair.
