Rs520 ssd suggesion
dear Sir:
recently got RS520.
WHICH VOLUME , BRAND, AND TYPE SSD SHOULD I BUY?
2TB OR 4TB? SAMSUNG OR WD OR CRUCIAL? NVME OR SATA?
THANKS FOR ANY SUGGESTION …
@drelvischen73
what size of sata ssd can fit in this rs520? thanks!
@drelvischen73
Above, we explained the Sata SSD specifications that fit RS520.
You must use SSD with a size of 2.5 inches and a thickness of 6.8~7mm
I use the Samsung 4TB SSD in two RS-520s and they’ve been great and fast. I used a 2TB USB 3.0 thumb drive to transfer a few traunches of FLAS files from my NAS…was easy.
