RS520 vu meter source
New RS520 owner, when setting up device, I was able to select input or output (may be labeled differently) as the source for the VU meters. Since setup, I have not been able to find this option in the menu, manual or online.
Any help appreciated, thanks
@C1A
First of all, I’m sorry for the late reply.
We were away last week to attend a hi-fi audio show in Germany.
The feature you described is currently not supported by Rose. There is no function that can display a different Vu meter for each music streaming app.
  1. If you want a function that always displays the Vu meter when playing music streaming apps, you can select the desired Vu meter in Rose device–>Settings–>Display–>Vu mode settings.
  2. If you want to change the Vu meter on the Vu meter screen, touch the Vu meter screen and click Change Theme on the top right corner to change it.
