Dear All
I have a new RS520.
When I stream Spotify over Air Play from an Iphone, the vu meters do not move at all.
What kind of settings do I need to apply to make the vu meters working?
Best Regards and Thanks,
Loris
Dear All
I have a new RS520.
Loris
We have also confirmed that the Vu meter does not work when connecting a Rose device and an iPhone via Airplay.
We will fix this issue as soon as possible and distribute an update.
And if you want to play Spotify music, there is a way to connect the RS520 and iPhone to the network through the Spotify Connect app.
When connected via Spotify Connect, the Vu meter is supported normally.
Thanks a lot for the quick answer and explanation!
Looking forward for the update. And for the time being will try to use the Spotify Connect app.
Many thanks and best regards,
Loris
Any progress/update on providing a fix supporting VU meters using AirPlay? It‘s quite disappointing for a RS150B - +€4000,- device that this basic functionality is still missing.
