RSA720 firmware
Does anyone here have a copy of the latest firmware for the RSA720 USB hub? Like many on here, I’m having issues connecting to my dac via the 720 and seems like a firmware update is the way to solve it.
Many thanks in-advance!
Ninja
@Ninjapunchtl
Please request the RSA720 update file via the email below.
Then I will deliver the update file to your email.
Hi ROSEHAN,
I just purchased a RSA720 and my Holo Audio Spring 3 KTE DAC is unable to detect the Rose USB hub. Can you please send me a copy of the latest firmware as well. Thanks in advance.
@Deepblue
I have sent you the RSA720 update file and manual.
Please check your email.
Did you send to my e mail as well? I have asked so many times!
@Yu3319
Please let me know your email address.
I will send you the RSA720 update file again.
I have sent the RSA720 update file to all the users who requested it from me.
Here is my e mail: mingy3319@gmail.com
Thanks!
@Yu3319
I have sent you the RSA720 update file and manual to the email you provided.
I own a RSA720, RSA780 and a RS130.
Would You please be so kind and send me the Firmware for the RSA720.
Thank You in advance and kind regards.
Mischka
@Mischka
Also just purchased the RSA720 and my DAC is not recognised. Did the new firmware solve your issue?
Thanks for your advice on this.
Tom
I have an RSA720 on order but just realized that I will not be able to do any updates if I don’t own a Windows PC (we are a Mac house). Does anyone know if there is a way to update firmware without a PC (and I am not installing an emulator and trying to do that for an optical hub). Why can’t the RS130 do the update when connected to the RSA720? This whole process seems like 1990s software.
I wasn’t able to update the firmware, even with a Windows PC
It is very likely that the RSA720 you ordered is with the latest firmware. Because the firmware that Hifi Rose sends you is not recent either…
Can anyone send me the latest firmware update for RSA 720?
Please send me the rsa 720 firmware update to my email at kchong88329@netvigator.com. Thank you!
@kchong88329
I have sent the RSA720 update file and instruction manual to your email address.
Please let us know which part cannot be updated, and also inform us of the results after completing the update.
Dear Seong Han,
Thank you for sending me the update file, I am currently in China right now, I will let you know by this weekend regarding what works for my RSA720. Thank you!
Best Regards,
Eddie Chong
@kchong88329
Yes, if you experience any other issues besides this one, please let me know.
At the begining of the update, I have trouble getiing my computer to recognized the drive, the vl810filter.sys was block by the windows security due to non secured driver. But at last, I have solved the problem by editing the registry in order to make it work. I successfully updated the firmware for both usb 2.0 ports sucessfully, but the version of firmware you sent to me was 82.00.42.00 instead of 92.00.42.00 shown in the manual “How to update RSA720 VL671 FW.xlsx file”. I am not sure of you sending me the latest firmware updates for my RSA720?
