If I wanted to watch a live concert video stream, for example, that isn’t on Rose Tube/You tube but rather another streaming service, can I run TV audio through the RS250? Believe my TV has optical out. Can that be connected to optical in on the RS250 and run audio from TV?
Yes it is possible
TV sound can be played through RS250.
As you said, connect the optical out port on the TV and the optical in port on the RS250.
Good morning!
I was wondering the same thing; can I run the TV through the Rose? If I run the optic cable from the TV into the Hi Fi Rose, which output setting on the menu do I select to hear the audio? Also, have you noticed improved sound from your TV by running the signal through the Rose rather than straight into your amp?
Good morning.
If you want to hear the TV sound through RS250, you need to make sure that the audio setting in the TV setup menu is set to optical output, and the RS250 must be set to optical input from the in out settings.
