Welcome team
I notice that when watching the concert on lg tv with the cable s/pdif turned on, the signal break every a few minutes. I have the latest update on rose 250
Can you solve the problem?
Best regards
Jacek
Welcome team
Best regards
Jacek
I have this experience, I renew another fiber cable and solved problem. The problem was caused by the weakness of light transfer thru’ the fiber due to some damage.
It comes out that the cable has a slight contamination. Alcohol and clean swipe solved the case
