Samsung S21FE couldnt connect to Rose150B
I have a tablet S8+ connects without problem to my Rose 150b.My new cellphone Samsung Gallaxy S21FE is not able to connect.
I put the good IP address of my streamer but there is another IP address called RoseConnect IP which is 192.0.0.2 and is
wrong in my opinion since the same address on my Samsung Tab is: 192.168.2.17. The screen that appears on my cellphone block everything and I dont have the option to change this RoseConnect IP.
I attached the picture of my cell phone screen.
I have the last version 4.6
All my computers work perfectly but my new cell phone the cell Huawai works also
Please advise.
Regards
Harry
@harry33
To connect your Rose device with the RoseConnect app, the IP address connected to the Rose device and the IP address of the device you are using when using the RoseConnect app must be the same.
In simple terms, you must be connected to the same Wi-Fi.
  1. Is your Rose device connected to the same Wi-Fi as the device used when using the RoseConnect app?
  2. To connect your Rose device and the RoseConnect Premium app, they must be connected to the same IP network. Even if Rose device is connected by LAN cable, it must be connected to Wi-Fi of the same IP in your mobile phone.
Connect to your RS150B via LAN from your router.
RS150B—>Settings—>System Info—> IP address shown in IP Address and Wi-Fi IP connected to your phone Up to two points must be same.
Example) Correct
Ethernet IP Address: 192.168.4.44
Android IP Address: 192.168.4.33
Example) Wrong
Android IP Address: 192.168.6.33
  1. If it is not connected even though it is connected to the same Wi-Fi, delete the RoseConnect Premium app from your mobile phone and download it again and try again.
