After the purchase, I saw that the screen resolution of a cheap device from 2010 was very terrible and pixels were visible. It’s now 2024 and it’s strange to see such a resolution for $5,000. It just looks terrible. When will there be a high resolution screen that will match the purchase level?
Mine looks nothing like this. Perhaps you need to disable zoom in your eyeballs
Oui l’ecran doit avoir un gros soucis : retour boutique, qu’attendez vous ?
I just got used to the monitor and other devices and expected the screen resolution to be much better. I assumed that the resolution would be like that of a phone or monitor and that no pixels would be visible. HD resolution in 2024 is a dubious pleasure.
[image]
The LCD on the RS150b we have looks the same as yours.
We will gradually strive to create better products.
I already got it. I liked the Rose rs150b so I hope that in the near future you will have higher resolution screens and will change to a new model.
