Hi, yes I did.
It’s not sizing to my screen properly - it’s chopped off at the bottom.
Is it a Mac desktop supported device?
I’m sorry the RoseConnect for Windows and MAC are in beta version.
How did you set the display resolution for MAC?
A bit larger than normal. I am assuming that once the Beta version has been improved that it will fit to a user’s preference?
I made it smaller and it worked.
If there are any parts that need to be updated, we will update them. However, we appreciate your understanding that not all updates can be done at once. Even if it is a little slow, we will improve each inconvenience one by one.
We apologize for any inconvenience.
