Great job, Rose. The VU meter screensaver has turned out really well!
Looks great. May I know which RD160 firmware version you are using?
Never mind. I found it comes with v1.51.
Installed the new firmware. The UV meter does look good but unfortunately it’s not very responsive.
In terms of sound quality, I personally prefer the v1.24 I’d been using.
I reverted everything back to where it was after a few hours.
Do you still have the 1.24 software?
Yes I do. Give me your email and I’ll send a copy to you.
Or you can ask Rose staff to send it to you if you prefer.
Is there a save way to send it to you? I don’t want to make my email public.
Click on the Big Name Circle in front of this message. Then you can choose to send PM.
I have already sent you a PM.
We will strive to provide further improvements in the next firmware update.
Thank you for your feedback on the RD160 update.
Can you tell us what has changed in the sound quality?
I found it a bit “loose” than the older version. The old one is more assertive.
My personal feeling, anyway.
'Just installed R.1.56. Nice spacial in sound. First impressions are very promising. Well, for sure depending on individual system-setup and personal taste …
