Hello
Rose connect for windows does not have the side scroll option in the folder area.
windows 10 pc.
ROSEHAN thanks for reply.
it’s not my case.
I have three more shared folders that I can’t see because I don’t have a scroll bar.
We apologize for the inconvenience during use.
There is no scroll bar on the screen, but does the scroll function work?
Hello ROSEHAN
it works with the mouse wheel but as I don’t use a mouse on my laptop, I had to configure the touchpad to scroll with two fingers. but it would be nice to have a scroll bar.
Thank you for your help
Hi, There used to be a scroll bar on the folder, and when I have a huge list of albums in that folder list. But that disappeared in the last 3-4 months when an upgrade was done. Forgot which one it was.
PC RoseConnect–>Music–>Folder–>Storage–>Do you mean that there is no scroll bar on the right side of multiple albums?
Yes @ROSEHAN. The scroll bar used to be there before.
Now I have to use my trackpad on the laptop or manually scroll up and down, which is a pain if you have a large number of entries you have to scroll through
