Hi community,
I contacted my android ( xiaomi ) to rose rs 150 b and try to search for music in my android but i can’t find any options to search from my android phone…i need to search only from the screen of my rose…do i missing something ???
Please someone can give me tip what to do ? It very uncomfortable to get up to tap on the rose screen … many thanks
Itshak
Hi Roseloa,
Can you please advice me what to do ?
Also, i sent you home page of radio station to add…is it possible to add them ?
I didn’t get any feedback from you.
Itshak
- Please check if your RS150B and your phone is in same network.
What do you see when you start the RoseCoennect APP?
About radio, please check your ROSE device.
Hi Roseloa,
Yes, the same network.
I attached screen shot of my phone after i get to roseConnect to tidal /youtube and i can’t find any options for search song /artist…
Only option is to go to tidal /youtube and then to search in the app not from roseConnect and to use the Bluetooth to connect to rose.
This option is poor because it uses Bluetooth…
Please let me know what to do and many thanks for add Israel radio station.
It is great !!!
Itshak
Screenshot_2022-01-08-21-05-22-372_com.citech.rosepremium.remote|225x500
Hello, what is the language setting on your phone?
When I set the language of my phone to one of the Middle East Asian countries, the symptom you mentioned appeared.
ROSE team will try, but unfortunately it will take some time to fix.
Sorry to tell you this.
Hi Roseloa,
The language is Hebrew and unfortunately you absolutely right !
I changed the setting to English and the search is working !
Please try to fix that because it really annoying
I understand that it will take time… but please try to focus on the problem…
Many thanks
Itshak
