Hi fellow hifi rose, I have an integrated amp and I would like to safely set the mV on the rose 150b. My input sensitivity is 600mV on the amp and on the rose 150b there’s only 500mV or 1000mV, could someone advise me? Thank you in advance
I’m happy to answer your questions.
If the input sensitivity of the integrated amplifier you use is 600mV, set it to 1000mV in the RS150b pre-out level setting.
If clipping occurs when playing a sound source, change the preout level setting to 500mV.
Thank you kindly for your time and quick response!
