Hi.
I use an atoll dr200 as a driver connect to the Rose via the AES input
I would like to use the CD shortcut on the main screen rather than pressing In/out>AES in the menu.
Is it possible?
Have a nice day.
Hi.
Is it possible?
Have a nice day.
After connecting your DR200 and RS150B with AES, you will change IN/OUT setting as AES IN.
Once you selected AES IN, it won’t change until you change even after reboot.
