Hi Rose!
Why is ‘n it working, when I push the “shuffle-icon” on my iPhone (playing in Qobuz) and it does when I push it on my RS150b??
Can you tell me?
Thanks in advance,
Theo
Same problem here. Did shuffle ever work for you or Did your problem start after recent update?
Hi RBear,
I must say I don’t know exactly, because I never used this option before, but lately I wanted to shuffle a playlist and I discovered the malfunctioning from my iPhone….
I may have discovered solution, for my iPhone at least…
Tap on song from the playlist you want to shuffle. While that songs cover is the only thing on the screen, tap the shuffle icon. That seems to reset shuffle for the entire playlist that the song came from.
Hi RBear!
I followed your instructions and it worked for me as well, so many thanks for that!
So I think, this is a very nice platform to get rid of your (my!) problems….!
