I am having serious speed problems navigating and transferring files to rose rs150b hd. The transfer of files from pc to rose hd via smb or ftp protocol is terribly slow. I can only copy at 5mb / s max. I checked the cables and connections and everything is ok. With the nas I communicate at 100mb / s.
hello,
It may happen if you transfer many small files,
- Is 5mb/s max even when transferring one big file, such as a video file?
- Is your storage in RS150B a USB? HDD? SSD?
- Is your RS150B connected to network with Ethernet?
1 I use high quality audio files (60mb per file). Therefore they can be considered large files. I didn’t try with video files. Anyway I’m used to transfer all types of files (small and large ones) in my network at significantly higher speeds even on standard hhd.
2 I have attached an ssd both via usb and internal.
3 Yes
i have the same problem…how was it solved?..can you help me? thank you
Until Rose will not stop using the old, slow and unsecure SMB V1, there exists no solution for the problem.
For initial filling the disc, you can put it out from the Rose and connect it directly to your PC.
