Software Bugs more and more
After the last update, there is a massive problem with the Digital Out. It constantly loses its connection to the DA converter. And the LAN connection also causes difficulties. Please fix errors immediately or I will sell the device. The software is full of bugs and that with a device for over 4000 €, what are you doing?
  1. Which ROSE device are you using? RS150B? RS250? RS201?
  2. And the LAN connection also causes difficulties
    → Do you mean that your ROSE device with LAN connection is constantly connected and then disconnected?
  3. What’s the model name of your DAC?
  4. Did you connect to your DAC with USB? Coaxial? Optical? Or else?
  5. What did you play? Qobuz?
We apologize for any inconvenience.
