If I use the RS250A as a pre-amp and switch on the Software Volume Control, it introduce a quite audiable hiss when music is playing and the volume is set to minimum 1.
I have testet it with two devices, and it’s the same on both of them.
It only appears if I stream (I’m using Spotify Connect), not when the TV is connected to the RS250A trough optical.
If I turn the Software Volume Control off, the hiss dissappear, but I have to turn the volume quite up when listening to music/using any source compared to when it’s on. I.e.: volume 20 when the feature is on is around 40 when it’s off.
